Boss13
Boss13 Aug. 13, 2024, 10:36 a.m.
What's the best rc glider for a beginner with some cash to burn?
Just got a fat bonus at work and thinking of treating myself to an RC glider. Always wanted to try it out but never pulled the trigger. Looking for something that won't fall apart on the first flight but also won't require a PhD to fly. Any suggestions? Budget's flexible but let's not go crazy. Also, any tips for a newbie? Stuff you wish you knew when you started?
Cheers!
BSN57
BSN57 Aug. 19, 2024, 8:01 p.m.
Check out the hobbyzone carbon cub s 2. Solid beginner RC glider plane. Easy to fly but still fun when you get better. Thank me later.
Ajk
Ajk Aug. 13, 2024, 2:51 p.m.
Nice one on the bonus! For your first rc glider, look for something with "trainer" in the name. They're usually more forgiving and can take a beating. Electric is the way to go for beginners - way less hassle than nitro.
sc3217
sc3217 Aug. 14, 2024, 5:13 p.m.
Dude, whatever you buy, find a massive open field for your maiden flight. Nothing sucks more than watching your new toy get eaten by a tree on day one. Don't ask how I know this...
madmuss
madmuss Aug. 15, 2024, 12:22 p.m.
Gliders are cool and all, but have you considered a powered plane? Might be more fun for a beginner.
bob_dalas
bob_dalas Aug. 16, 2024, 6:56 p.m.
Nah, gliders are where it's at. Nothing beats the feeling of catching a thermal and just soaring.
SBW
SBW Aug. 15, 2024, 9:43 p.m.
Before you buy, hit up FliteTest on YouTube. They've got some great beginner guides that'll save you a ton of headaches.
Chak013
Chak013 Aug. 16, 2024, 7:39 p.m.
Anyone mention checking the wind yet? Seriously, it's crucial. When you're starting out, you want it dead calm or you'll be chasing your plane across the county.
forte
forte Aug. 17, 2024, 1:34 p.m.
If you've got the cash, the Volantex ASW28 is pretty sweet. It's a step up from beginner models, but not so advanced that you'll crash it immediately. Good to grow into.
black_smoke
black_smoke Aug. 18, 2024, 11:35 a.m.
before you even think about real flying, get a sim. Way cheaper to crash virtually than to rebuild your glider every other flight.
BSN57
screamhome
screamhome Aug. 19, 2024, 11:43 p.m.
Hold up, we just glossing over the "fat bonus" part? Forget RC, I've got some magic beans that'll double your money! xD
cfyz3
cfyz3 Aug. 20, 2024, 1:17 a.m.
Dude, chill. Let the guy have his fun. Boss13, ignore this clown. RC gliding is awesome, you'll love it.
sdfgsdb
sdfgsdb Aug. 20, 2024, 4:38 p.m.
If you're even slightly handy, think about building one yourself. Kits are way cheaper and you'll actually understand how to fix the thing when (not if) you eventually crash it.
nickleback
nickleback Aug. 21, 2024, 9:38 p.m.
Don't skimp on batteries if you go electric. Cheap ones are a fire hazard. LiPos aren't something to mess around with.
EvilM.D.
EvilM.D. Jan. 11, 2025, 10:01 a.m.
learn weather patterns first. thermal activity peaks around noon, rookies flying at sunset wondering why no lift
toor2009
toor2009 Feb. 8, 2025, 10:31 p.m.
Transmitter signal dropped mid-flight and my glider said "aight imma head out" 💀
Mega 2
Mega 2 Feb. 27, 2025, 11:55 p.m.
flying field etiquette important. unwritten rule - help others find crashed gliders, they'll return favor
uepbr
uepbr March 14, 2025, 8:30 p.m.
Spent 20 mins chasing what i thought was my glider. Turned out to be a plastic bag fr fr
GT
GT March 28, 2025, 10:12 p.m.
rc groups forum saved me hundreds. used market actually decent if you patient
frost85
frost85 April 13, 2025, 7:40 p.m.
Bro my E-flite Radian got violated by wind last week but survived somehow?? Gyro system clutched, rookie mistake turned into skill check real quick
Gamiet
Gamiet Aug. 7, 2025, 12:56 a.m.
"budget's flexible but let's not go crazy" said every guy who later showed up to the field with a 6S setup and a $400 transmitter. we've seen this arc before Boss13, just embrace it
pilot2407
pilot2407 Jan. 16, 2026, 8:39 p.m.
Got an E-flite Night Radian 2.0m last spring, wing bolts on in two pieces so transport is actually not a nightmare. The LED thing seemed gimmicky at first but genuinely useful for orientation when the light gets flat and grey outside
angelcharlie
angelcharlie April 9, 2026, 5:22 p.m.
One thing that helped me a lot early on, thermals don't appear randomly. Asphalt and dark rooftops heat way faster than grass or water, so if you're flying near a parking lot or a gravel yard you're basically parked over a thermal generator. Birds circling in a lazy spiral with no wing flapping is the other dead giveaway
twinki
twinki June 1, 2026, 1:02 p.m.
worth checking before you buy whether the glider is locked to its own proprietary transmitter or if it takes a standard receiver. A lot of the RTF bundles come with a basic 4-channel TX that you'll outgrow in 4 months, and then you're either stuck or buying a new radio anyway. If it accepts a standard receiver from the jump you can upgrade the tx independently without rebuying the airframe
z1322
z1322 Aug. 21, 2026, 10:44 p.m.
lost orientation on my third flight. glider coming at me, i push away, it goes straight into the dirt.
physics: 1. me: 0.
