Colombina
Colombina Jan. 16, 2025, 7:29 p.m.
What's the best RC crawler choice in $400-600 range?
Yo RC fam! Super stoked to finally dive into crawling after watching tons of YouTube vids. Got a budget of $400-600 for my first 1/10 scale rig (can stretch a bit if really worth it).
Been mainly looking at the Traxxas TRX-4 and Axial SCX10 III since they seem to be the go-to choices in this range. Also spotted the Redcat Everest-10 which is way cheaper - wondering if it's worth saving the cash or if I should stick with the premium options?
Looking for something that can:
  • Take a beating (cause I'm gonna crash for sure lol)
  • Handle parks and rocky terrain near me
  • Good parts availability when I break stuff
  • Decent for learning the basics
Also, should I set aside some of that budget for batteries and upgrades? Any must-have accessories I should know about?
Thanks in advance! Really appreciate any advice from you experienced crawlers! 🙏
moon 2
moon 2 Jan. 17, 2025, 10:32 a.m.
TRX-4 Sport (~$400) is your sweet spot here. Save the extra cash for a good battery/charger combo.. The full-feature TRX-4 is sick but honestly the Sport version has everything you need to start 💪
nikoleta
nikoleta Jan. 18, 2025, 7:16 p.m.
FIRST!!1!1
ThomasMT
ThomasMT Jan. 20, 2025, 10:17 p.m.
Set aside about $100 for a proper LiPo setup. The Redcat comes with a battery but you'll want to upgrade that pretty quick 🔋
Mike_b
Mike_b Jan. 21, 2025, 4:37 p.m.
The Sport is plenty of crawler for learning. The fancy features on the full TRX-4 are cool but you won't miss them as a beginner. Save that cash for batteries and upgrades.
Full
Full Jan. 25, 2025, 9:19 p.m.
Been in the hobby 5+ years, here's the real deal:
TRX-4 Sport ($420):
  • Perfect beginner crawler
  • Tough as nails
  • Huge parts availability
  • Leaves room for battery/charger
SCX10 III ($530):
  • More advanced features
  • Better out of box performance
  • Might stretch your budget thin
  • Still need battery/charger
Redcat Everest-10 ($200):
  • Surprisingly capable
  • Ready to run package
  • Great learning platform
  • Upgrade as you go
Honestly? Start TRX-4 Sport. Perfect mix of quality and budget.
colins93
colins93 Jan. 29, 2025, 7:20 p.m.
Ran all three. The Redcat's great if you're not sure about the hobby. But if you're committed, that TRX-4 Sport is worth every penny. Just get aluminum steering links first upgrade 🤘
puma-loco
puma-loco Jan. 30, 2025, 4:21 a.m.
lol that budget could get you a PS5 instead bro 🎮
alexsis7777
alexsis7777 Feb. 5, 2025, 12:21 p.m.
my crawler gets more fresh air than you ==> 🌲🌲🌲
tomash
tomash Feb. 1, 2025, 5:42 p.m.
Been running both TRX-4 and SCX10 III. The Axial just feels more premium tbh. Better steering geometry and weight distribution. But for a beginner? Probably overkill.......
AndBor
AndBor Feb. 3, 2025, 10:26 a.m.
7 years in the hobby and best thing I did was joining the local RC group. Learned more in two meetups than months of YouTube. Plus these dudes always have spare parts when you break something (and you will lol)
matt
matt Feb. 4, 2025, 8:23 p.m.
SCX10 III owner here - yeah it's at the top of your budget ($530) but the quality is insane. Portal axles and aluminum links out of the box. Just know you'll need another $100+ for electronics setup.
truejackk
truejackk Feb. 6, 2025, 7:24 p.m.
SCX10-3 is like buying a Ferrari as your first car. Amazing crawler but maybe too much for starting out? That's basically your whole budget on just the rig
accere
accere Feb. 9, 2025, 7:58 p.m.
my hot wheels collection worth more than these toys 🤡
Germes
Germes Feb. 19, 2025, 2:38 p.m.
Yo, quick tip about crawlers - don't freak when it seems slow af. These things aren't built for speed, they're for torque. My TRX-4 barely hits 10mph but climbs like a mountain goat on steroids. You want that low speed control for the gnarly stuff.
hero
hero June 4, 2025, 10:19 p.m.
One thing nobody's saying, whatever you pick, budget like $80-100 on top for a decent charger not just a battery. The stock chargers that come bundled with RTR kits are usually trickle-only bricks, takes forever and gives you no info about cell balance. A proper balance charger changes the whole experience
denis_777
denis_777 Nov. 26, 2025, 9:33 p.m.
running the axial scX10 iii wrangler since last summer, portal axles make a real difference on loose rocky stuff. had it upside down in a creek bed twice, dried it out and kept going
shliff
shliff April 12, 2026, 3:49 a.m.
bro asking about $600 crawlers but can't be bothered to google "what is a portal axle" first. the dedication is inspiring tbh 🙏
rum800
rum800 June 21, 2026, 11:10 p.m.
Since lipo came up a few times, worth knowing: a battery that starts puffing is not just a dying pack, it's actively dangerous. Swelling means gas buildup inside the cell. Stop using it, don't charge it, take it outside. Plenty of guys have lost benches or garages because they figured "eh, one more run"
Laser
Laser Aug. 2, 2026, 3:51 p.m.
crawler won't fit under the couch anymore
wife suspects nothing
