zmay 355
zmay 355 Feb. 19, 2025, 10:51 p.m.
Basement theater almost done - need best electric projector screen recs!
Finally finishing my basement theater after years of putting it off. Got the projector (Epson LS800), sound system, and comfy seating figured out, but stuck on which electric projector screen to get. Budget around $300-500 but can stretch if worth it. Room is completely light-controlled (no windows), about 15x18ft. Thinking 100-120" but not sure if that's too big? Ceiling height is 7.5ft. Some walls have exposed pipes/ducts so ceiling mount probably best. Never installed one before so worried about messing it up. Want something reliable that won't start sagging after a month. Any brand recommendations or installation tips? Thanks!
to-dreams
to-dreams Feb. 20, 2025, 2:05 a.m.
Motorized screens need maintenance. Consider fixed frame unless you absolutely need to hide it when not watching
piero
piero Feb. 20, 2025, 7:33 p.m.
your ceiling height is the limiting factor here - measure twice! most 120" screens need 8ft+ for proper placement
sereettet
sereettet Feb. 21, 2025, 9:24 p.m.
whatever you do, spend extra for tab-tension. non-tensioned screens develop waves over time that ruin image quality
Rwiffy
Rwiffy Feb. 22, 2025, 12:11 a.m.
+1 this advice saved my setup. tab-tension costs more upfront but pays off long term
F/G/
F/G/ Feb. 23, 2025, 6:52 p.m.
picked up aoxun electric motorized for my office last month - surprisingly good for the price point. silent motor and even drop. handling 4k content without issues
Conti
Conti Feb. 24, 2025, 8:17 p.m.
Home theater installer here: always factor in $100+ for proper mounting hardware. The included screws couldn't hold up a paper towel let alone a 25lb screen. Seen too many movie nights end with a $400 crash test dummy experiment 💀
jaman
jaman Feb. 25, 2025, 1:40 a.m.
reminder that optimal viewing distance = screen diagonal × 1.5 (minimum) to 2.5 (maximum). plan your seating accordingly
mitZO
mitZO Feb. 25, 2025, 10:48 p.m.
consider acoustic transparent if you've hidden speakers behind screen position. otherwise sound reflection becomes problematic
tOOlSMeN
tOOlSMeN Feb. 27, 2025, 1:26 p.m.
120" is actually borderline too small for that room size. i'd go 135" minimum given your dimensions
Davidjonser
Davidjonser March 2, 2025, 5:22 p.m.
ceiling mounts near HVAC vents = bad news fr fr. trying to watch anything with text becomes like reading earthquake mode subtitles. whole setup be hittin the wobble 🥴
aventador
aventador March 7, 2025, 9:38 p.m.
Get sample swatches of screen material before committing. Different materials perform wildly differently with same projector
jonnny
jonnny March 10, 2025, noon
wish i'd done this. white screen material looks yellow-ish with my epson. should've gone gray
Thrt,ekfy
Thrt,ekfy March 16, 2025, 11:48 p.m.
hidden cost warning: electrical work to add proper outlet near mounting location can add $200+ to project if DIY not option
6q76oi
6q76oi March 24, 2025, 10:51 p.m.
Running Akia Screens 125" Motorized in similar setup - perfect size for that room. Installation wasn't terrible solo but definitely easier with helper. Motor still quiet after 18 months
CccRccC
CccRccC March 31, 2025, 1:22 a.m.
make sure remote frequency doesn't interfere with other devices. my screen and soundbar got married without permission - hit one button and chaos ensues. screen goes brrrrr every bass drop 🤣
lara1109
lara1109 April 5, 2025, 3:33 p.m.
Black borders essential for perceived contrast improvement. Avoid screens without substantial black masking
lol_1
lol_1 April 11, 2025, 4:49 p.m.
Check out that screen ratio article on GG. Saved me from making a huge mistake with my setup
18l18l
18l18l April 16, 2025, 8:13 p.m.
Calculate throw ratio properly before purchasing anything. Epson LS800 needs specific distance from lens to screen for optimal image
uecfh
uecfh April 24, 2025, 6:05 p.m.
don't forget acoustic treatment unless u want that premium 4K image to sound like ur watching movies through a drive-thru speaker. priorities bruhhh 💯
