vvval
vvval March 15, 2025, 4:36 p.m.
Enterprise Storage Upgrade - need help choosing best enterprise ssd
Running into serious performance bottlenecks with our current storage setup and finally got budget approved for enterprise-grade SSDs. We're a mid-sized financial services company with about 200 employees running multiple database workloads and VDI environments.
Current setup is mix of aging Dell PowerEdge servers with traditional HDDs in RAID10, and they're struggling to keep up during peak trading hours. Database queries timing out, VMs lagging, the works.
Need guidance on best enterprise ssd options that can handle high write endurance and consistent IOPS. Planning to purchase 20-30 drives initially. IT team pushing for NVMe while finance wants to save with SATA. Not sure which vendors deliver best reliability these days.
Top priorities are endurance, consistent performance under load, and something with decent warranty. Bonus points if anyone has actual failure rate data beyond vendor marketing claims!
Noryhywog
Noryhywog March 15, 2025, 10:56 p.m.
don't even LOOK at consumer drives with enterprise workloads... watched helpdesk team learn this lesson hard way when they "saved money" then spent entire weekend restoring from backups after 8mo premature failure
banker
banker March 16, 2025, 12:12 p.m.
Finance "saving money" on storage always costs more in long run. 30min system downtime probably exceeds entire price difference between enterprise/consumer drives. Print TCO analysis, hand to finance, end discussion
dosjk
dosjk March 17, 2025, 4:07 p.m.
Financial sector = compliance headaches. Check if your regulations require drives support secure erase/crypto erase for decommissioning. Learned this $43k lesson at previous bank job
africa
africa March 17, 2025, 9:24 p.m.
Deployed WD 2TB Red SA500 in similar environment last quarter. Solid mid-tier option if budget tight but beware - sustained write performance dips noticeably under heavy concurrent workloads. Kinda expected at that price point tho
DiorFB
DiorFB March 18, 2025, 5:59 p.m.
NVMe worth every penny for database workloads. Latency difference transformed our organization - quarterly reports that took 3hrs now complete in 17min. Users thought we replaced entire infrastructure when we just swapped storage
knj
knj March 19, 2025, 1 a.m.
hard numbers talk. benchmark current setup vs proposed then present actual business efficiency metrics to stubborn finance folks
koz
koz March 20, 2025, 11:05 p.m.
Run IDENTICAL drives in all slots or face mysterious performance dips that'll take weeks to diagnose. Mixing enterprise drive models became my personal IT Vietnam
14
14 March 22, 2025, 12:01 a.m.
tracked 4 critical metrics across 15 drive models under simulated db load:
1) avg latency @ 70% capacity
2) p99 outliers under load
3) 24hr sustained write degradation
4) power loss recovery times
results almost never matched vendor claims. dm if you want raw test data
demodern
demodern March 23, 2025, 2:02 a.m.
Painfully accurate... Switched drives after extensive testing then discovered our ERP system used completely different I/O pattern than test suite. Performance barely improved despite $18k investment
a.m
a.m March 26, 2025, 4:39 p.m.
Lasted 9 months as storage vendor sales engineer before quitting. Insider tip: those "reliability ratings" based on cherry-picked controlled tests that simulate nothing like actual production workloads. All while customer support scripts literally tell us to blame "environmental factors" first
Herobrine Slime
Herobrine Slime March 31, 2025, 10:06 p.m.
Swapped 140 drives to Intel D3-S4510 across four datacenters last year. Rock solid with insanely consistent latency even under 90% capacity. Initial cost felt painful but zero failures + performance stability worth every penny
ggggg
ggggg April 6, 2025, 7:15 p.m.
Went full NVMe on critical systems, kept ancient SANs for backups. Saved $$$. Nobody notices storage until it breaks, then everyone screams. Spend where it matters, cheap out on the rest. 8yrs zero major incidents with this philosophy
nfnmzyfv
nfnmzyfv April 12, 2025, 11:01 p.m.
bro skip manufacturer supplied firmware. grab latest updates direct from manufacturers before deployment. discovered critical bug AFTER installing 84 drives... unscheduled maintenance weekend fixing what updated firmware would've prevented
akller
akller April 16, 2025, 5:08 p.m.
Enterprise drives seriously overpriced for what they deliver. Consumer drives in proper redundant configuration provide 90% performance at 50% cost. Fight me
dstiml
dstiml April 19, 2025, 1:03 a.m.
exactly why our shipping database went offline for 3 days last year. redundancy doesn't protect against firmware bugs affecting entire batches. $450k in lost revenue for $12k "savings" 🤡
phil228
phil228 April 26, 2025, 3:16 p.m.
One factor everyone overlooks: write amplification effect on flash memory cells in high-transaction environments. Dramatically affects drive lifespan beyond stated endurance ratings when workloads have high update frequency
dreml
dreml July 19, 2025, 4:53 p.m.
quick q does ur raid controller actually handle nvme without extra cards or is that another hidden cost? we mapped our iops last week and half the lag was queue depth not the drives themselves
shinode
shinode Nov. 27, 2025, 11:13 p.m.
We had the same poweredge + hdd nightmare with our vdi pool so last quarter we dropped the Gigastone High Endurance SSD in the test cluster and its been eating the random writes fine ever since
SANTA058
SANTA058 Jan. 31, 2026, 6:26 p.m.
finance always picks sata to "save money" then acts shocked when the array pukes during peak hours and ur whole team works weekend restore lmao classic
k101010k
k101010k April 16, 2026, 1:57 a.m.
enterprise ssd upgrade be like buying a tank to haul groceries and hoping finance doesnt notice the receipt 😂
xmaxx1981
xmaxx1981 Aug. 1, 2026, 9:29 p.m.
For db + vdi the sustained performance under real load is what actually decides if ur queries stop timing out not the headline iops numbers
