Littl
Littl March 29, 2025, 1:54 p.m.
Need help choosing best led garage lights for my new workshop setup
Just finished clearing out our garage to turn it into a proper workshop space. Finally getting around to upgrading the ancient single bulb that barely lights half the area. The space is about 24x20ft with 9ft ceilings, and I'll be using it for woodworking, car maintenance, and general DIY projects.
Been looking at LED options since they seem most energy efficient, but completely overwhelmed by choices. So many different styles, brightness levels, and mounting options. Not sure if I should go with the flush mount panels, shop light style, or the newer fold-out adjustable head models.
Main priorities are good coverage without shadows, bright enough to see small details (especially when working on engines), and not needing to replace them for years. Would prefer something I can install myself without hiring an electrician.
Any recommendations from people who've actually upgraded their garage lighting? Budget is flexible for something that will last.
AYNEL
AYNEL March 31, 2025, 11:30 p.m.
Tried 3 different setups in my workshop before landing on the ontel beyond lights. Really solid brightness for detail work and the adjustable panels let me direct light exactly where needed. Surprisingly easy install for someone with basic DIY skills
R83
R83 March 29, 2025, 9:27 p.m.
Basic 4ft LED shop lights from any big box store offer best bang for buck. I mounted six in my similar sized space in grid pattern, total cost under $200. Make sure they're linkable to minimize wire runs
ху+z
ху+z March 30, 2025, 12:23 a.m.
Buy once, cry once. After 3 rounds of "budget" garage lights that flickered/failed, bit the bullet on commercial grade. Spent $450 but haven't touched them in 5 years while my neighbor's replaced his twice. Look for die-cast aluminum housing and proper diffusers - these matter more than the LED chips themselves
sinister_alfa
sinister_alfa March 30, 2025, 8:20 p.m.
Temperature matters WAY more than most realize. Those ultra-bright 6500K cool white lights will drive you insane after an hour. Go with 4000-5000K range for workshop - bright enough for detail work without the harsh operating room vibe. Made this mistake and had to replace everything
if
if March 31, 2025, 11:38 a.m.
your ceiling height is the key factor. at 9ft, you need minimum 100 lumens per square foot for woodworking, 150+ for automotive work. calculate total space (24×20=480sqft) so aim for fixtures totaling 48,000-72,000 lumens combined. specs matter more than marketing names
AYNEL
termiator
termiator April 1, 2025, 7:09 p.m.
SHADOWS are workshop enemy #1. Better to have more lower-lumen fixtures spaced properly than fewer ultra-bright ones creating harsh shadows. Test this: hold wrench under single bright light vs multiple less bright sources - difference is night and day for seeing details
Fibanachi
Fibanachi April 2, 2025, 4:31 p.m.
Skip ceiling lights entirely and invest in portable task lighting instead. Ceiling fixtures always end up putting shadows exactly where you're working
My setup: modest ambient overhead lighting + quality task lights I can position directly on what I'm doing
lex30
lex30 April 3, 2025, 8:02 p.m.
Game-changing advice! Switched to this approach last year - 4 basic overheads + 3 movable LED work lights. Finally no more shadows exactly where I'm trying to see tiny screws or read measurements
vampir
vampir April 4, 2025, 6:54 p.m.
Don't overlook the wiring! Many garages only have 1-2 outlets on a single 15A circuit. Adding several high-draw LED fixtures can overload. Check your panel before buying - may need electrician to add dedicated circuit which adds $200-400 to project cost
men PRINCE
men PRINCE April 7, 2025, 10:33 p.m.
Garage insulation dramatically affects lighting needs. My uninsulated space requires roughly 30% more lumens in winter than summer due to light absorption by dark, cold surfaces. Factor this in if you live somewhere with temperature swings
k2553551
k2553551 April 11, 2025, 3:19 p.m.
Tested dozens of options for my classic car restoration. Surprisingly, the Hexagon Garage Light outperformed fixtures costing twice as much. Adjustable panels provide perfect coverage under car and the color accuracy helps when matching paint and finishes
zttn
zttn April 17, 2025, 11:34 p.m.
One feature worth paying extra for: instant-on at full brightness in cold temperatures. Cheap LEDs dim significantly below freezing and take minutes to reach full output. Crucial if you live anywhere with real winters
Tranceman
Tranceman April 24, 2025, 12:50 a.m.
Three $25 linkable shop lights from Harbor Freight + white paint on walls and ceiling = perfectly lit workspace for under $100. Stop falling for marketing gimmicks and 8-blade "deformable" lights that'll break in a year
UAKAMI
UAKAMI April 29, 2025, 8:01 p.m.
The most overlooked specification when choosing workshop lighting is the Color Rendering Index value. Standard LEDs with CRI 70-80 make it nearly impossible to distinguish similar colors (critical for wiring or woodworking). Invest in high-CRI (90+) fixtures for accurate color perception, especially if doing finish work or painting
belkinsword
belkinsword May 4, 2025, 1 p.m.
positioned my lights AFTER setting up workshop layout rather than standard grid pattern. mapped shadow zones while doing typical tasks, then installed fixtures specifically to eliminate them. unorthodox approach but zero regrets
ThatBit
ThatBit May 6, 2025, 10:37 p.m.
This is actually genius. I've been fighting shadows for years and never thought to plan lighting around actual usage patterns instead of symmetric spacing. Going to redo my entire setup this weekend
striker
striker May 13, 2025, 8:42 p.m.
Converted old fluorescent fixtures to LED instead of buying new. Retrofit kits cost half as much as new fixtures and reuse existing wiring. Took about 20 minutes per fixture with zero electrical knowledge
globalhome
globalhome May 19, 2025, 10:58 p.m.
Installed proper LEDs and my persistent headaches disappeared. Turns out fluorescent ballasts were emitting high-frequency flicker my eyes couldn't detect but my brain sure felt. Worth every penny just for the quality of life improvement
231177
231177 May 27, 2025, 7:30 p.m.
Installed those fancy "solar tube" skylights alongside LEDs. Natural light during day, electric at night. Best decision ever. Even basic models dramatically reduce energy costs, and watching storms roll in while working on projects adds unexpected joy to garage time 🌧️
morfi
morfi July 21, 2025, 3:15 p.m.
Work on cars professionally all day, still spend evenings on personal projects. Proper garage lighting non-negotiable for detail work. Eyes aren't getting younger, adequate illumination safety issue as much as convenience
djoker 05 05
djoker 05 05 Sept. 3, 2025, 9 p.m.
Started woodworking channel, didn't anticipate lighting being biggest challenge. Garage lighting upgrade improved video quality more than camera investment. Content creation teaches unexpected lessons about production fundamentals
bpan
bpan Nov. 20, 2025, 2:17 a.m.
Converted garage into workout space during pandemic. Good lighting motivation factor somehow - dark garage encourages skipping exercise, bright space inviting. Psychology of environment underestimated in fitness discussions
redbul16
redbul16 Dec. 22, 2025, 7:01 p.m.
sinister_alfa absolutely certain 6500K will drive you insane. UAKAMI absolutely certain CRI under 90 makes color matching impossible. Tranceman absolutely certain all of this is marketing gimmicks. Vampir absolutely certain you need to check your circuit first. everyone in this thread is an authority and they all disagree. Littl just pick something
200888
200888 Feb. 15, 2026, 11:50 p.m.
Cheap LEDs with poor driver circuits create a stroboscopic effect where spinning blades can appear to slow down or stop moving. Same physics as spoked wheels in old films. It's a real safety hazard, not just an eyestrain thing. Look for fixtures marketed as "flicker-free" or with a high-frequency driver
5ok5
5ok5 April 7, 2026, 5:21 p.m.
Ran six hykolity 4ft linkable across my 22x20. Daisy-chained off two outlets, zero drama. Two years in, same brightness day one. Boring answer but sometimes boring is the answer
miTior
miTior June 30, 2026, 8:55 p.m.
The white ceiling/walls tip from Tranceman is undersold. Did mine before installing anything and suddenly i needed way fewer fixtures than calculated. Reflection is doing 30-40% of the work in a bright shop. If your walls are bare OSB or grey concrete block you're fighting the room not lighting it
jj07
jj07 Aug. 28, 2026, 10:05 p.m.
lit up the garage perfectly. went out there the next morning with coffee, full visibility. could now clearly see every single project i'd been procrastinating for three years
