Dols96
Dols96 April 10, 2025, 11:40 a.m.
Sketchy backyard needs lighting ASAP - what are the best outdoor motion sensor lights?
Just bought this old 70s house (yay housing market nightmare) and the backyard is straight-up horror movie dark. Like can't-see-your-hand-in-front-of-your-face level darkness once the sun goes down.
Wouldn't care that much BUT we've had a couple break-ins down the street last month, and my wife is freaking out every time she hears a noise at night. Pretty sure I saw someone cutting through our yard last week too, so now I'm paranoid af.
Need to light up several dead zones - back patio, side fence (where someone could easily hop over), sketchy wooded area, and the detached garage. Trying to avoid dropping thousands on a professional security system for now.
Total n00b at this stuff but can handle basic DIY. Have some existing light fixtures by the doors I could replace, but the problem areas would need something new. Solar would be clutch for the spots without wiring.
Any recommendations that won't break the bank but also won't die after the first rainstorm? Bonus points if they don't light up for every squirrel that runs by!
TIM
TIM April 10, 2025, 7:59 p.m.
Contractor perspective: go METAL not plastic housings. Spent 20+ years replacing melted plastic fixtures that "survived" one summer in Texas heat. Aluminum housings from literally ANY brand outlast fancy plastic ones 5:1 regardless of price. Materials > features every time
Space 2
Space 2 April 10, 2025, 11:34 p.m.
ended up mounting hunting trail cameras before lights ($40 at walmart)... caught neighbor's teenagers cutting through yard, showed parents video, problem solved without spending hundreds on lighting nobody actually needed. maybe identify WHAT you're dealing with before solutions?
Hommer2007
Hommer2007 April 11, 2025, 6:05 p.m.
DONT. MOUNT. ON. VINYL. SIDING. 🙃 ask me how i know cries in melted house wall... Thermal expansion destroyed both siding AND fixture requiring $1200 repair. Use wooden mounting blocks designed specifically for this purpose only. No youtube tutorial mentioned this critical detail
Urb
Urb April 12, 2025, 12:46 a.m.
Bought house last march, panicked about security, dropped $800 on "professional" lighting system that tripped constantly... discovered actual issue was overgrown landscaping creating perfect hiding spots. $150 bush trimming fixed security problem better than any lighting could
19092005
19092005 April 12, 2025, 8:55 p.m.
We tried the "better safe than sorry" approach with mega-bright floodlights and ended up hating ourselves. Couldn't enjoy backyard evenings, kids couldn't sleep with light blasting windows, neighbors complained weekly. Switched to focused path lighting instead of overhead floods - MUCH better security (can actually see faces) without light pollution nightmare. Don't create mini stadium lighting unless you enjoy angry neighbors
overtip
overtip April 12, 2025, 10:47 p.m.
This is exactly why we returned those ridiculous 3000-lumen monsters after two nights. Felt like living inside a Walmart parking lot. Now using multiple smaller lights strategically placed = perfect visibility without the prison yard vibe
Blogger
Blogger April 13, 2025, 7:26 p.m.
fyi those fancy dusk-to-dawn photocells fail WAY sooner than the LED lights themselves. Now have perfectly good lights permanently stuck ON wasting electricity 24/7. Buy fixtures with EXTERNAL/REPLACEABLE photocells or manual override switch for when sensors inevitably die
lollollol
lollollol April 14, 2025, 10:02 p.m.
Grabbed the URPOWER Solar Lights during Prime Day sale - absolute GAME CHANGERS for our weird yard layout. No wiring needed, each light covers about 20ft diameter, and they've survived six months of Florida downpours without issues. The adjustable sensitivity actually works unlike other brands we tried that triggered for literally every leaf movement
;tytxrf
;tytxrf April 17, 2025, 6:49 p.m.
Disabled homeowner warning: check activation height carefully! Most default installations detect average adult height (5'7"+) but miss wheelchair users/children. Had terrifying experience being stuck outside undetected by my own security lights. Proper installation = detecting ALL legitimate movement regardless of height
539
539 April 22, 2025, 11:11 p.m.
Consider light DIRECTION/SPILLAGE during installation. poorly aimed security lights create dangerous contrast between over-lit and shadow areas, actually decreasing visible security. proper design illuminates approach paths evenly rather than creating spotlight effect
a_a_c
a_a_c April 27, 2025, 3:18 p.m.
Our town's "dark sky ordinance" nearly got me fined $500 for standard downward-pointing floods - had no idea these regulations existed until citation arrived. Check local codes before installing ANYTHING - rural vs suburban vs urban rules completely different and actively enforced
8100
8100 May 2, 2025, 9:02 p.m.
The biggest misconception is that beam lumens matter more than proper coverage. A strategically placed 600-lumen light provides better security than randomly installed 1200-lumen blasters creating harsh shadows that actually hide movement. Coverage pattern trumps raw brightness
maki18+
maki18+ May 7, 2025, 4:20 p.m.
LOCATION MATTERS MORE THAN BRAND. Even $300 lights perform terribly when mounted incorrectly. Corners provide better coverage than flat walls. Above 8ft prevents tampering but creates detection blind spots. Under eaves protects from weather but reduces range. Spent hours repositioning until coverage finally worked right
Semmi-0
Semmi-0 May 9, 2025, 10:53 p.m.
Painfully true! Our expensive system was "defective" until maintenance guy moved two lights about 4 feet each. Suddenly perfect coverage and reliable detection. Installation location is literally everything with these systems
LarDreamn
LarDreamn May 14, 2025, 7:09 p.m.
Caved and bought Ring Floodlight Cam Pro after three cheapo Amazon lights failed in under 6 months. Yes it's pricey ($249) but 3D motion detection is actually game-changing - distinguishes between cars/people/animals and only alerts for actual threats. Worth every penny for sleep quality alone
qwerty21
qwerty21 May 20, 2025, 11:17 p.m.
Anyone with dogs: position sensors ABOVE their height or you're dooming yourself to constant false alarms! Our golden retriever triggered lights every 10 minutes until we adjusted sensor height. Test by having family member crawl vs walk through detection zone before finalizing placement
mail94
mail94 May 27, 2025, 1:44 a.m.
lol everyone recommending $200+ solutions when command hook + $15 portable LED camping lantern = perfect temp solution until you figure out permanent needs. been using this "emergency" setup for...uh...2 years now 💀 sometimes good enough actually is good enough
