Wiz*
Wiz* April 24, 2025, 12:03 a.m.
What's the best wifi temperature sensor for home?
So I'm having an issue with my basement home office that's driving me nuts. Moved my whole work setup down there last month (WFH permanently now) and the temperature is all over the place.
Some days it's so cold my fingers go numb while typing. Other days it feels weirdly muggy and my gaming PC starts sounding like a jet engine from the extra heat. Starting to notice some discoloration on one wall which has me paranoid about mold.
I want to get some kind of wifi temperature sensor thing that can:
  • Track temp/humidity over time
  • Send alerts if it gets too cold/hot/humid
  • Let me check conditions remotely (when traveling)
My brother-in-law suggested some crazy DIY Arduino setup but I'm not that tech savvy. Just want something that works without needing an engineering degree to set up.
Bonus points if it works with Google Home since that's what I already have, but not a dealbreaker.
oksin
oksin April 24, 2025, 2:12 a.m.
Don't overthink this. Bought an AcuRite from Home Depot for like $25. Not wifi but tells me temp/humidity and tracks high/low. Sometimes analog > digital. You're probably checking your phone every 5 mins anyway so just glance at it when you're down there lol
ogiman2
ogiman2 April 24, 2025, 12:59 p.m.
I have 3 sensors in my house all different brands and tbh they all suck in different ways. Wyze one disconnects constantly. Amazon one eats batteries like candy. Govee one works ok but app is trash. Pick your poison i guess
27456ssmpga
27456ssmpga April 24, 2025, 5:14 p.m.
Let me save you hours of research - go with Govee H5179. Best bang-for-buck on the market right now. $35, connects directly to 2.4GHz wifi (no hub needed), calibration feature, data export, decent app, alerts work reliably. Been running 4 of them for 18 months, only changed batteries once
RichardMsk
RichardMsk April 24, 2025, 11:41 p.m.
We installed 4 different sensors after finding black mold behind our basement TV last winter. Ended up realizing our problem wasn't temp but air circulation. No sensor will fix the underlying issue friend. Invest in a dehumidifier and box fan before fancy monitoring gadgets!!
dyx
dyx April 25, 2025, 12:06 a.m.
Came here to say this!!! Monitoring alone won't solve anything. Our $300 dehumidifier from Costco did more than all the sensors and gadgets combined. Best purchase we made all year
schtorm.VS
schtorm.VS April 25, 2025, 10:52 a.m.
Important factors to consider that most people overlook:
  1. Battery life (WiFi sensors are notoriously power-hungry)
  2. Sampling frequency (cheaper units might only update every 30-60 min)
  3. Cloud dependency (will it work if internet goes down?)
  4. Data retention policies (how long is history kept?)
  5. Export capabilities (can you download your data)
Happy to elaborate on any of these points if needed
igooEn
igooEn April 25, 2025, 4:10 p.m.
Nobody mentioned the UbiBot WS1 yet? Shocked tbh. Got it after water heater leaked last year. Not the prettiest but rock solid reliable + app doesn't require account creation which i appreciate for privacy reasons. Battery lasted 7+ months so far
Emergency
Emergency April 25, 2025, 11:54 p.m.
bruh just use an old android phone with temp sensor + IP Webcam app! free solution that works with any home automation setup. why buy dedicated sensor when you probably have spare phones collecting dust? can even set up motion detection as bonus security cam
anisim
anisim April 27, 2025, 6:01 p.m.
The key challenge with residential temperature monitoring is finding the optimal balance between temporal resolution and power consumption. Consumer-grade sensors typically sacrifice frequent measurements to achieve acceptable battery life, which can hide brief but significant environmental fluctuations that contribute to mold growth conditions
SYR
SYR April 30, 2025, 3:55 p.m.
May be overkill for your situation but I installed a full Ecowitt system after hurricane flooded our first floor. Weather station outside + 3 temp/humidity sensors inside. Gateway plugs into router, everything else wireless. Rock solid for 2+ years now. Can view data on phone/computer and set alerts. Initial setup bit tricky but worth it long term
FoxMavi
FoxMavi May 2, 2025, 12:19 a.m.
I hated all the subscription-based options so i got an inkbird. Simple cheap no monthly fees. Literally just works. Wish more things were like this tbh. Sometimes i think these companies intentionally overcomplicate stuff to justify charging more 🙄
qteks110
qteks110 May 7, 2025, 7:44 p.m.
After extensive testing in my 100+ year old basement, I've found the Proteus AMBIO - Wifi Temperature Humidity sensor to be surprisingly effective. The build quality isn't premium, but the sensor accuracy matches my professional-grade equipment within ~3% relative humidity. Battery performance exceeds specifications if you reduce sampling frequency to 10-minute intervals
land94
land94 May 11, 2025, 9:56 p.m.
why waste $$ on fancy wifi gizmos??? get a $5 temp gauge from walmart & take pic with your phone if u need "history tracking" lolol. these companies laughing all the way to bank selling y'all glorified thermometers with an app 😂😂😂
2KD
2KD May 14, 2025, 5:22 p.m.
Not everyone wants the most basic solution, Jake. Some of us value convenience and proper data logging. Not everything cheaper is better - my "glorified thermometer with an app" alerted me to freezing temps when I was away, saving thousands in potential pipe damage. Worth every penny
liod4
liod4 May 20, 2025, 10:09 p.m.
Make sure whatever you get has CALIBRATION feature!! My first three sensors showed wildly different readings in same location. Had to use ice water test to figure out which was accurate. Most consumer sensors are ±2-3°F off out of box. Absolutely maddening if you're data-oriented person like me
Swallow
Swallow May 24, 2025, 12:07 p.m.
We use wyze sense kit things for this. Not perfect but cheap & easy to setup. App sends notifications when temp drops/rises outside your settings. Bought originally to monitor our vacation cabin pipes in winter but now have them all over house. They go on sale frequently at home depot
AkiTo
AkiTo May 29, 2025, midnight
Take a step back and ask what problem you're actually solving. Are you just curious about conditions or trying to identify specific issue? If wall discoloration, you likely already have moisture problem that needs addressing regardless of monitoring. Temperature fluctuations in basements normal but humidity over 60% consistently = trouble. Fix the root cause first, then monitor to verify solution working
hlecik22
hlecik22 July 28, 2025, 10:57 p.m.
yo real talk tho - that wall discoloration is NOT a "monitor and see" situation lmao. dehumidifier first, sensor second. been wfh in my basement 4 years, learned this the expensive way. once you get air moving right, grab a SensorPush HT1 - it's bluetooth by default but add their gateway and boom, check it from anywhere. no subscription bs, just works
83@10
83@10 Oct. 2, 2025, 12:33 a.m.
Your bro-in-law's arduino idea isn't WRONG per se but bro... you'll spend an entire saturday on it and still end up with something uglier and less reliable than a $40 off-the-shelf thing 💀 speaking from experience. twice.
Nokia C3
Nokia C3 Feb. 15, 2026, 7:59 p.m.
Genuine question nobody asked yet: what's the actual floor situation? Like is it concrete slab with no vapor barrier? Because if so no sensor in the world fixes that, moisture just comes up through. Friend had exact same symptoms - temp swings, wall staining, weirdly muggy - turned out previous owner literally just painted over water damage. Sensor would've just showed you a problem you already knew you had lol
15llqq
15llqq May 1, 2026, 3 a.m.
sorry but "good luck with that kiddo" from the IT guy… about a TEMPERATURE SENSOR…. king behavior honestly
30
30 Aug. 15, 2026, 11:23 p.m.
the historical graphs thing is genuinely underrated ngl. mine showed humidity spiking every morning around 7am on the dot - took me a week to figure out it was correlated with my upstairs shower draining through a pipe behind the basement wall. never woulda connected those dots without timestamped data. whatever sensor you get, make sure it logs properly
