clbber
clbber May 1, 2025, 7:23 p.m.
Help me find the best soundbar for samsung tv - desperate for better sound!
So I finally caved and bought a Samsung 75" Neo QLED after months of saving up, and wow the picture is incredible but the sound is straight garbage. Like seriously, how do they make TVs this thin and expect the speakers to not suck??
My apartment situation is pretty typical - living room connected to dining area, couch about 8-9 feet from TV, hardwood floors with some rugs. TV is mounted on the wall because my cats destroyed the last TV stand (RIP).
Here's what's driving me crazy:
  • Can barely hear what people are saying in shows/movies
  • Have to turn volume way up then get blasted during commercials
  • Netflix shows are worst - everything sounds like mumbling
  • Gaming audio is weirdly echo-y and delayed
  • Neighbors already complained once about late night volume
Really want something that fixes the dialogue issue without breaking the bank or taking up half my living room. Samsung's website has like 20 different soundbar models and I have no clue what the difference is between them all.
Has anyone dealt with similar issues? What actually worked for you?
ST
ST May 1, 2025, 10:59 p.m.
Samsung soundbars sync way better with Samsung TVs through their proprietary connection stuff. Tried mixing brands before and spent hours troubleshooting random audio delays and remote control conflicts
775
775 May 2, 2025, 6:40 p.m.
honestly your apartment layout sounds fine for any decent soundbar. the dialogue issue is probably more about the soundbar having a dedicated center channel for voices rather than room acoustics
SEOmasterx
SEOmasterx May 3, 2025, 12:01 p.m.
cats + electronics = eternal struggle lmao. Whatever you get make sure it's not too low to the ground or your little monsters will think it's a new perch/scratching post
cll123123
cll123123 May 3, 2025, 8:36 p.m.
Upgraded to samsung's q800a series last year after similar frustrations with my QLED's audio. The 3.1.2 setup with dedicated center channel completely solved dialogue clarity issues and the wireless sub means no cables for cats to destroy. Worth every penny for daily use
mixon
mixon May 6, 2025, 11:42 p.m.
Netflix audio mixing is genuinely terrible lately and no soundbar fixes that. enable subtitles and save yourself hundreds of dollars. not even kidding - their sound engineers apparently don't own TVs
PIANO
PIANO May 8, 2025, 1:10 p.m.
Apartment living means you probably want something with night mode or dialogue enhancement features. Being able to hear conversations without waking neighbors at 11pm is clutch
Siid
Siid May 12, 2025, 9:03 p.m.
Skip Samsung soundbars entirely and get Sonos Arc. More expensive but actually good instead of just "TV brand matching" marketing nonsense. Samsung's audio division makes mediocre products compared to their display tech
Sailor
Sailor May 14, 2025, 11:22 a.m.
The problem with non-Samsung soundbars is codec compatibility becomes hit-or-miss with newer Samsung TVs. Sonos might sound great but you lose seamless integration features like automatic volume leveling and source switching that make daily use actually convenient
adopus
adopus May 16, 2025, 6:53 p.m.
Just get whatever's on sale at costco. Unless you're some audiophile snob you won't notice difference between $300 and $800 soundbars. They all make sound louder than TV speakers = mission accomplished
xbirf
xbirf May 17, 2025, 12:45 a.m.
check if your Samsung TV has specific soundbar recommendations in the settings menu. Newer models suggest compatible audio equipment that's been tested with that exact TV model
ErBol008
ErBol008 May 20, 2025, 7:11 p.m.
Tested bunch of different options in my similar apartment setup and Samsung's basic HW-A450 series ended up being perfect middle ground. Simple 2.1 setup that dramatically improved dialogue without overwhelming small space or requiring complex configuration
na62392
na62392 May 23, 2025, 10 p.m.
Wait before u spend $$$ did u actually dig into ur tv settings?? Mine had this "voice clarity" thing buried in audio menus that made dialogue way better. Felt dumb after almost buying soundbar when free setting fixed most of my issues lol
WARLEX
WARLEX May 25, 2025, 4:27 p.m.
HDMI eARC is clutch if u game at all. regular ARC has noticeable delay that drives u crazy once u notice it. learned this the hard way with my ps5 setup - upgraded to eARC soundbar and night/day difference
040654
040654 May 28, 2025, 8:13 p.m.
Been there with the neighbor complaints! Look for soundbars with adjustable bass and night modes. Being able to hear dialogue clearly at low volumes is worth more than earth-shaking explosions that get police calls
qwerty21
qwerty21 May 31, 2025, 5:48 p.m.
samsung's own soundbars are fine but overpriced for what you get. Vizio and tcl make comparable models for way less money. Brand matching is mostly marketing unless you need specific smart features
kph
kph June 4, 2025, 10:32 p.m.
gonna sound weird but... have u considered just using headphones? got some decent bluetooth ones for like $80 and now i can actually hear everything without blasting volume. neighbors stopped hating me and honestly sounds better than most cheap soundbars anyway 🤷‍♀️
big-boss
big-boss Aug. 21, 2025, 8:15 p.m.
ok so ur cats destroyed a TV stand but u want a soundbar on the floor lmaooo respect the chaos. wall mount bracket for the bar exists btw, same ones that hold the TV. zero floor real estate, zero cat surface area. been living this life for 3 yrs
Jadi7777
Jadi7777 Nov. 13, 2025, 11:10 p.m.
The Samsung HW-B750F was exactly what fixed my dialogue issue in a similar setup. Dedicated center channel so voices don't get buried under everything else, night mode actually works at 11pm without waking my whole building. It's not the fanciest thing but ngl it does exactly what you need
112123121
112123121 Jan. 23, 2026, 1:19 p.m.
bro the gaming audio delay ur describing is 100% because ur TV is using regular ARC not eARC. switch to eARC port, enable game mode on the TV, GONE. this is not a soundbar problem this is a settings problem. took me two weeks to figure this out and i was losing my mind
a.m
a.m May 4, 2026, 10 p.m.
Your neighbor who complained about the volume IS the reason dialogue modes exist as a feature. The whole point is you can hear every word at like volume 15 instead of 40. Once you get that working correctly the neighbor situation basically solves itself. source: am the neighbor in this story at my previous apartment
wollff
wollff Aug. 19, 2026, 12:21 a.m.
unpopular opinion but the Netflix mumbling thing is legitimately a content mixing issue, not just your speakers. that said a soundbar with a dedicated center channel pulls dialogue forward from the rest of the mix in a way flat TV speakers physically cannot, so it helps a lot even if it doesn't fully fix netflix specifically
