Argonim
Argonim June 13, 2024, 10 a.m.
What's the best portable projector for business presentations under $500?
Hey all,
I'm in the market for a portable projector for business presentations. I travel frequently for work and need to give PowerPoint presentations to clients, but I'm tired of relying on the hit-or-miss equipment provided at different venues. I have a Dell XPS 15 laptop with an HDMI output, and I'm looking to invest in a reliable, portable projector that I can easily carry with me and set up quickly. It needs to be compatible with my laptop and have good image quality, preferably with at least 2000 brightness, even in rooms that might not have ideal lighting. My budget is around $500, but I'm open to spending a bit more if it means getting a high-quality, durable device. I'm primarily interested in projectors from brands like BenQ, ViewSonic, and Epson.
Thanks in advance for your insights!
MonteShot
MonteShot June 14, 2024, 7:17 p.m.
The Epson Powerlite e20 (epsv11h981020) is a great choice for your needs. It offers 3400 lumens of color and white brightness, XGA resolution, and weighs just 5.5 lbs, making it easy to carry around. It's compatible with your Dell XPS 15 via HDMI, and the price is around $500, which fits your budget perfectly. I've used this model for my own presentations, and it's been very reliable.
MonteShot
BuddyTom
BuddyTom June 20, 2024, 2:25 p.m.
The PowerLite E20 is a good choice, but don't forget to consider factors like keystone correction and zoom capability. These features can be lifesavers for business presentations in different room setups. The E20 offers both vertical and horizontal keystone correction, as well as a 1.2x zoom, which should provide some flexibility in positioning the projector.
buffo
buffo June 16, 2024, 10:22 p.m.
I might be old-school, but I still think a flip chart and markers can sometimes be more engaging. No tech issues, no compatibility worries. Plus, it adds a personal touch. But hey, I get that tech has its perks too!
Yammso
Yammso June 18, 2024, 8:22 a.m.
Another great option is the Benq MS560. It delivers 4000 ANSI lumens, SVGA resolution, and weighs about 4.4 lbs. MS560 also has various connectivity options, including HDMI, making it compatible with your laptop. The price is around $400, so it's well within your budget. I’ve had good experiences with BenQ projectors, they offer excellent image quality and are quite durable.
noa
noa June 21, 2024, 4:33 p.m.
I've used both the epson powerlite e20 and benq ms560 for presentations, and they both perform well. The Epson has slightly better image quality and color accuracy, while the Benq is a bit brighter and more affordable. Ultimately, both projectors should serve you well for business presentations, so it might come down to personal preference and specific features you prioritize.
Warman
Warman June 22, 2024, 9:34 p.m.
To compare the Epson PowerLite E20, BenQ MS560, and other similar models, I suggest checking out the ProjectorCentral website. They have detailed reviews, side-by-side comparisons, and a helpful tool that lets you filter projectors based on your specific needs. This can help you make an informed decision that suits your requirements and budget.
Cliemapem
Cliemapem June 25, 2024, 12:37 p.m.
I’ve found that having good keystone correction is essential, especially in awkwardly shaped rooms. Make sure the projector you choose has this feature. Also, consider the throw distance, some projectors need to be quite far from the screen to produce a large image, which isn’t always feasible in small meeting rooms...
GregoryBeimb
GregoryBeimb Nov. 18, 2024, 3:26 p.m.
Thanks for helping save time with the choice!
adok767
adok767 Jan. 29, 2025, 3:04 p.m.
Telling clients "just a moment" while you spend 15 mins finding the perfect angle is the true business presentation experience 😭
ager
ager Feb. 9, 2025, 10:55 p.m.
imagine spending $500 on a projector when you could just email the presentation like a normal person
albert2
albert2 Feb. 16, 2025, 2:32 p.m.
until your client's wifi decides to take a coffee break mid-meeting 💀
albn
albn Feb. 25, 2025, 12:16 p.m.
Yo check the throw ratio before buying unless you wanna present from the parking lot
aleks9
aleks9 March 13, 2025, 6:44 p.m.
Grabbed that ViewSonic PA503W last month and no cap - 3800 lumens + low latency got my powerpoints looking crispy af. worth the $489 frfr 🔥
6709
6709 March 28, 2025, 10:58 a.m.
anybody else's projector fan sound like it's about to achieve lift off or just mine?
vipflex
vipflex April 9, 2025, 12:50 a.m.
Anything under 3000 lumens is basically a fancy flashlight in rooms with windows ngl
by
by June 1, 2025, 9:01 p.m.
Territory covers three states, presentations happen in bizarre locations. Projected quarterly results in Denny's parking lot once when client's office flooded. Portable projector earned its cost that day alone, plus free Grand Slam breakfast from impressed manager
06081958
06081958 Aug. 13, 2025, 4:24 p.m.
Writing grants for underfunded organizations means convincing rich donors with compelling visuals. Borrowed projector died mid-pitch to potential six-figure sponsor. Never again. Own equipment now, anxiety levels decreased substantially, hair stopped falling out as rapidly
Slame7
Slame7 Oct. 8, 2025, 6:55 p.m.
Pre-planning seminars require sensitivity and professionalism. Projector that crashes during "affordable cremation options" slide destroys credibility instantly. Learned this mortifying lesson at senior center. Invested in reliability over features, death industry has zero tolerance for technical difficulties
tsubar84
tsubar84 Dec. 19, 2025, 8:02 p.m.
the cremation options slide is genuinely the most high-stakes presentation scenario i have ever read about in a projector thread. godspeed Slame7
kailas
kailas Jan. 31, 2026, 11:11 a.m.
buffo said flip chart adds a personal touch. i want buffo to walk into a 2026 boardroom with a flip chart and markers and personally touch the exit door on the way out
44Android44
44Android44 March 29, 2026, 2:13 a.m.
Been burned enough times by venue walls that i pack a 4lb folding screen now. Cream-coloured, slightly textured plaster in a cleveland conference room nearly killed a pitch i'd spent two weeks prepping. Added about $60 and half a kilo to the kit and haven't thought about it since
YSJFQGX
YSJFQGX June 1, 2026, 3 p.m.
worth knowing: when brands print "3800 lumens" on the box that number is almost never ANSI lumens which is the actual industry standard. it's usually measured from a single bright spot in the center. real-world brightness is often 30-40% lower. anything under 3000 ANSI with windows in the room is a gamble
Female_wolf
Female_wolf Aug. 2, 2026, 12:10 p.m.
Over op's budget but the Optoma ML1080 runs off a USB-C powerbank, no outlet needed. 2.2 lbs, comes with its own carry bag. I've presented from places that had zero accessible wall sockets and it just worked. Denny's parking lot would be fine
